ENGINE OVERHAUL KIT New power for old engines! Works like a cylinder and ring job while you drive--NEW POWER for cars, trucks, tractors, and boats Do it yourself in minutes! Save on expensive repairs! Controls burning oil...helps restore fit of worn parts Restores power...renews seal of valves and rings Quiets noisy engine and valve lifters Provides easier, all-weather starts...reduces exhaust smoking Developed by skilled automotive scientists after more than 6 years of research and laboratory and road tests! Simply drop pellets into the spark plug opening and pour engine overhaul liquid into the oil in crankcase. ENGINE OVERHAUL COMBINATION goes to work on worn areas of motor. While you drive, worn parts are plated with a metallic layer that actually renews finish and fit. Restored parts are protected and cushioned by the engine overhaul liquid, giving you thousands of miles of trouble-free driving. It flows onto bearings, valve, cylinder and piston surface, protecting them with a self-lubricating wear-resistant protective film. Pellets are special thermoactive metallic alloys. Heat and pressure of motor bond these alloys on to the worn, pitted, and scored metal of your cylinders and rings. Restores their fit, smoothness and power. No special tools or skills necessary...no need to take your motor apart. NOTE: Large 8’s (Cadillacs, Buicks, Oldsmobiles, Lincolns, Chryslers) require 2 packages. SKU Description Unit Price 16ZX0071T Complete Engine Overhaul Kit 1-Kit $7.99
