Ramrod..... ...NO NO NO!..... .NO FLASHIE THE FIELD. Thats the WRONG thing to do with the 3-wire 6-volt 8N-genny. UNDERSTAND??? Based upon yer brief description, YOU MISS-WIRED the genny barrel studs. (and its eazy to do) Yer genny barrel studs are actually labeled FIELD (this is an INSULATED post) and GND. (look closely) You have 2-skinny wires connected to the genny barrel from yer 4-terminal squarecan voltage regulator. The skinny BLACK with RED tracer is GROUND at both ends of the harness (genny barrel and squarecan VR attaching screw) The skinny BLACK with WHITE tracer is the INSULATED FIELD stud to squarecan "F" terminal. Iff'n you incorrectly grounded yer field and fielded yer ground as I suspect, then yeah, SPARKIES!!! It should be intuitively obvious, UN-CROSS yer genny barrel wiring and 'vola' yer correctly wired. Even though the colors are incorrect, electrons don't know the difference, isn't that amazing??? You'll be real lucky you iff'n you didn't MELT yer genny barrel wire insulation. Surprizingly enuff, yer genny didn't gitt hurt by being miss-wired. Wiring harness and squarecan voltage regulator, different story. Consider it a $15 lesson in how to wire yer simple tractor electrics..... ... respectfully, Dell
