PTO quit, what should I look for?
offroadr
06-07-2007 05:56:58
I am a newbie to 8Ns so any help is appreciated. Last night I was mowing and the PTO started sporatically disengaging. Later it quit altogether. I can tell that when I flip the PTO lever it does engage but the shaft out the rear isn't turning. Its like something is broke out back.
What should I look for? Thanks
Bob
06-07-2007 06:02:53
 Re: PTO quit, what should I look for? in reply to offroadr, 06-07-2007 05:56:58
Is there on ORC (Overrunning Clutch) slipped onto the PTO shaft, ahead of the mower's front PTO coupler?
If so, the ORC make have failed internally.
offroadr
06-07-2007 07:40:58
 Re: PTO quit, what should I look for? in reply to Bob, 06-07-2007 06:02:53
What would it look like? I honestly do not know.
Dell (WA)
06-07-2007 08:02:27
 Re: PTO quit, what should I look for? in reply to offroadr, 06-07-2007 07:40:58
third party image
offroadr..... ...heres a pic of ORC (over runing coupler) very necessary for N-Tractors PTO's driving brushhoggs. Without the ORC, everytime you clutch to slowdown to go around the barncorner, powerpole, creekbank, irrigation canel, wifes car (don't ask) all that brushhog blade inertia BACKDRIVES thru the PTO into yer tranny and yer brakes won't slow you. Held on by behind the greeze zerks with springloaded split rollpin. Comes in old 1-1/8F and new 1-3/8F inputs and modern 1-3/8M output ORC $60, cheap..... ..Dell, yer self-appointed ORC SAFETY preacher
Kenster
06-07-2007 10:44:32
 Thanks, Dell! in reply to Dell (WA), 06-07-2007 08:02:27
I've taken to heart what everyone has been saying for the past year since I got my 8n, that I need to get an ORC on it. Have been asking questions and was about to buy one. Then you go and post that picture. "Kinda looks familiar," says I. So out I go to have a look and, by golly, I already have one of those puppies on my tractor, exactly like the one you posted. Except that, opposite the grease fitting is a slotted head, rather than the hex head as is in the picture. I have no idea if it is a 'conversion' ORC or if there is a new PTO shaft. The ORC has a bit of slop when you jiggle it, and there a little bit of leak from the PTO seal, but my hydraulic fluid still measures to the 'full' mark on the stick so I guess I am not loosing much. I think I'll just leave it alone for the time being and save the bucks I was going to spend on a new PTO shaft assembly and ORC.
Thanks again!
offroadr
06-07-2007 08:38:04
 Re: PTO quit, what should I look for? in reply to Dell (WA), 06-07-2007 08:02:27
Thanks so much, yes I do have one of those, so that could of failed internally?
Ramrod
06-07-2007 09:45:23
 Re: PTO quit, what should I look for? in reply to offroadr, 06-07-2007 08:38:04
Grab it and see if it will spin in both directions. It shouldn't.
Dell (WA)
06-07-2007 08:52:06
offroadr..... ..yes, 1-way clutches fail. Remove with hidden rollpin. Remove BOTH greeze zerks and drive out with nail and hammer. Simple, eh?..... .Dell
offroadr
06-07-2007 12:22:02
 Re: PTO quit, what should I look for? in reply to Dell (WA), 06-07-2007 08:52:06
Thanks so much for the help!
