Beverage holder on tractor?
Kenster
06-08-2007 12:17:29
I'd like to come up with something to hold a water bottle in easy reach when I'm operating my 8n. I have a 'spare' hole in the top of my left rear fender or I could mount something under the bracket that holds my sun canopy to the rear fenders. I've thought about something as simple as drilling a bean can and bolting it to the fender. Not secksy but utilitarian.
I know many of you must have done something like this.
Ideas?
BTW, the first time I tried to send this, the board censors kicked it out for the use of inappropriate words! The only thing I saw that they could possibly be talking about was the correctly spelled version of "secksy." Although it could have been the word "rear."
DON TX
06-09-2007 12:17:32
 Re: Beverage holder on tractor? in reply to Kenster, 06-08-2007 12:17:29
Here is a pic of my cupholder. It has been great now for @ a year. 1 plastic tie and the cutout for the handle. It doesn't jiggle or bounce. HTH
DON TX
S Russell
06-09-2007 07:34:50
If the desire is for water, you could purchase a hydration pak, as used by our soldiers and outdoorsman. Probably not as workable for adult beverages.
johnhunt
06-08-2007 18:30:58
find you a old can and 1/4 by 1 1/2 bolt and bolt it in gReaT true redneck
john hunt
06-09-2007 05:37:25
 Re: Beverage holder on tractor? in reply to johnhunt, 06-08-2007 18:30:58
hey dunk yes I know lot more redneck here, but there a lot there to on that web site, so point is you not just only one so sorry . but poot that won't keep the beer cool. she more like for hot item , smiles ....
Poot
06-09-2007 04:46:03
 Hey John..... in reply to johnhunt, 06-08-2007 18:30:58
third party image
howziss for a "beverage holder"?
Dunk
06-08-2007 18:56:47
John, you know any TRUE rednecks!?!?!?
Dunk
06-08-2007 18:57:34
 Re: Beverage holder on tractor? in reply to Dunk, 06-08-2007 18:56:47
I mean besides me....
old
06-08-2007 14:40:18
A friend of mine has a coffee can bolted on the side of his Farmall 450 for a cup/bottle holder. It was on it when he got the tractor and when we painted it he said to leave it on so I did. Even has a slot cut in the side for a cup handle to fit in
lonestarjeff
06-08-2007 14:14:57
Ken....I came up w/ this using a boat drink holder & a piece of electrical conduit strap:
third party image
Worked fine & didn't require drilling any new holes in bodywork.
Jeff
Jack-Illinois
06-08-2007 14:05:15
How about a magnet used for a welder groung - fasten anything to it and stick it anywhere you want. (unless you have a lot of body filler or fiberglass on your "N")
Tim...Ok
06-08-2007 13:44:40
heres the one on my IH
third party image
Cargocult (CONSERVATIVE)
06-08-2007 12:49:47
Well, I have one on my N! It is a juice can, one of the 1-quart ones. Opened it and added a few holes in the bottom to drain out any moisture that would otherwise accumulate in there. Installed it on the screw that was used to add the cyclone pre-filter in place of the intake screen. Cost me less than a buck, full of juice. I maintain a couple of plastic drinkin" containers in my freezer full of water, which I sip on when usin" the tractor. Also works for coke, beer, mixed drinks, etc. However, these usually come in smaller containers, which tends to drop down into the can. Maybe I should rig up another unit 4 dese, hehehe. I had a fantasy about gettin" one of them there "Bar Bouys", but have spaced it out! Tha advantage of the USED quart juice can..it is expendable! CC
Kenster
06-08-2007 12:33:53
Oh, and just so you know... I did check the archives. There are some decent ideas there but I was hoping for a really outstanding idea.
I do like the idea of the PVC, Ramrod. I could paint it to match the tractor!
Tim...Ok
06-08-2007 12:33:38
my IH worker had three holes in the fender in a triangle pattern of unknown origin..I had some 3" muffler tubing,so I cut a slice of that,welded some tabs on it to match the bolt pattern in the fender..cut the head off of a 1/4" bolt and welded it across the bottom to keep the bottle from falling thru..works really well and gets used all the time..
Tim
Ramrod
06-08-2007 12:30:03
I've seen them made from a piece of PVC pipe with a cap on the bottom and holes drilled to let it drain. It can be bolted down through the bottom cap and painted to match.
