What to fill whith?
RDAllison
06-08-2007 16:37:43
How do I fill this hole so it is paintable ?
I tried to use epoxy but is not vary workable and it hardens to fast. Any suggestion?
Thanks, RDAllison third party image
Thanks, RDAllison
RDAllison
06-09-2007 07:12:53
 Re: What to fill whith? in reply to RDAllison, 06-08-2007 16:37:43
Thank you all for your help, it was much appreciated. RDAllison
soundguy
06-08-2007 23:11:49
Polyester fill 'bondo' was what I used.
soundguy
Kenster
06-08-2007 17:58:25
Hey, RD. Congrats on getting the picture posted.
I have a cancer on my hood in the same place but I have bigger things to fix first.
Good luck on your body work.
roger '40 9n
06-08-2007 16:50:27
I would use bondo and fiberglass window screen.
Stick the screen to the inside on some bondo and spread some more on top. Use a second layer if necessary.
Roger in Michigan
RDAllison
06-08-2007 17:01:27
 Re: What to fill whith? in reply to roger '40 9n, 06-08-2007 16:50:27
I went to the bondo Website and there are all kinds of fillers. could you recommend a type?
Thank you, RDAllison
At the vary bottom are the fillers.
Dunk
06-08-2007 18:04:41
 Re: What to fill whith? in reply to RDAllison, 06-08-2007 17:01:27
Body Filler
Dunk
06-08-2007 16:41:55
Bondo, or fiberglass, would be my suggestion
