Gas in crankcase
Rollie
06-13-2007 19:52:00
My 2N won't run but in the process of trying to revive it when I turn it over it squeals once every revolution which appears to be coming from the crankcase. Looked at the oil level and it looks like and smells like gas in the oil.
How does gas get into the crank case on an updraft carb? Even if the float stuck it should come out the carb intake rather than go up to the cylinders.
Any help?
souNdguy
06-14-2007 07:14:57
 Re: Gas in crankcase in reply to Rollie, 06-13-2007 19:52:00
Ya might also put a teaspoon of oil in each spark plug hole so that the gas washed cyls will have a little prelube onthem before they start going up and down real fast.
Even though the air intake pip at the mouth of the carb is low.. it travels up high to the top of the air cleaner.. up level with the gas tank. if the hose clamp and tube is good.. gas will eventually fill the carb, and the breather tube and the manifold.. all to the same level.. at some point the spill over into the valves, assuming you have enough gass in your tank.. Takes a bit to happen..
Change the oil.. think of this as a crankcase flush...
Soundguy
john hunt
06-14-2007 05:19:44
it common problem for it people forgot to turn of the gas they do make eletric valve type for it work great change the oil but use a real good oil for can relube motor...
arthur ward
06-13-2007 21:11:26
your fuel tank is up higher than the intake valves. law of physics there.
old
06-13-2007 20:42:20
Yes its sort of funny how gas does and will travel up hill in an up draft carb system and when it does it can and will destory an engine fast.
GAJIM
06-13-2007 20:02:41
Rollie: If your fuel cut-off valve doesn't completely turn off the gas flow, the same condition can happen even when you turn the gas off. I learned this the hard way. And, I've bought a new gas cut-off valve that was bad out of the package. GA Jim
Dunk
06-13-2007 19:56:50
Ummm, because you didn't turn yer gas valve off on the bottom of the tank when you got thru using her?
Yes it will, a minor leak on your float needle valve assembly will fill your crankcase with....
Guess what... Gas!!
Dunk
06-13-2007 19:58:19
 Re: Gas in crankcase in reply to Dunk, 06-13-2007 19:56:50
Drain it, put in new oil.
Turn yer valve off when you put er up.
