Ramrod..... ...somewheres I seem to remember a wattage spec for the "infamous ballast resistor" at 25-watts. You know of course, you can ALWAYS OVERSPEC WATTS of resistors. Iff'n you undespec resistor watts, guess watt??? kaboolie..... blown resistor. Good electronic engineering practice is overspec watts by factor of 3-time. (minimum) Don't forget the real reason for the "infamous ballast resistor" was weaksister 6-volt batterys. They didn't make die-hards back in 1939. And by making the "infamous ballast resistor" out of temperature sensitive resistive element, Ford automatically OVER-VOLTAGED the ignition coil when COLD and the 6-volt battery was weakest. The ballast resistor would automatically heat-up and increase its resistance to a nominal 0.7ohms in about 2-minutes running time. (ballast resistance varies from about 0.3ohm to 1.4ohm, depending upon its internal temperature) You do know that the squarecan ignition coil is really a 3-volt and 3-amp ignition coil, don't you? And that the infamous ballast resistor is NECESSARY to drop the 6-volt battery down to about 3-volts. I've seen all sorts of schemes to by-pass the MANDATORY & NECESSARY infamous ballast resistor for hotter-sparkies and quicker starts. They all have one great "weakness", they will MELT the squarecan insulative tars in about 1-hr and short-out internal windings and you endup with weak sparkies..... ....Dell, yer self-appointed sparkie-meister
