clutch alignment
RJ IN WYO
06-15-2007 09:37:48
need a little information on reinstalling my clutch on my ford 8n. just got my motor back from machine shop and reinstalling. since this is my first rebuild i have a guestion. is there a clutch alignment tool for 8n or a generic brand. the kids at the auto stores werent much help. I know there our homemade ones but need help in how to maake one. any help would be appreciated.
RJ IN WYO
06-15-2007 12:17:42
 Re: clutch alignment in reply to RJ IN WYO, 06-15-2007 09:37:48
Thanks guys i have never rebuilt atractor or motor in my life. feel better knowing there is help out there when i get in trouble. thanks
john hunt
06-15-2007 11:09:20
nine spine ford clucth tool work.. $3.00 most auto part some come with in the kits if top of line kits
Dell (WA)
06-15-2007 09:51:02
RJ..... .asked and answered many times in "archives" at the top of this great N-Borad.
But for you special..... ..use yer tranny input shaft. Just remove 4-bolts and vola', yer clutch disk centering tool. And while you have yer tranny input shaft out, REPLACE yer tranny input shaft seal $3 (cheap). Simple, eh?
Oh yeah, look closely at yer clutch disk hub, it is non-symmetrical. Long side facing tranny. Tighten clutch pressure plate bolts, 18ft/lbs after centering disk. I lightly sand the polished pressure plate and engine flywheel clutch facings, no need to have them resurfaced for tractor operations. Simple, eh?..... ...Dell
TheOldHokie
06-15-2007 09:42:59
Remove the transmission input shaft and use it. It's simple, quick, cheap, and will allow you to replace the shaft seal while you have the tratcor split.
TOH
Tom N MS
06-15-2007 17:40:51
 Re: clutch alignment in reply to TheOldHokie, 06-15-2007 09:42:59
Just removed one and it wasn't quite as simple as some say it is..Had to do some bumping and pulling and begging to get it to come out. I was beginning to think I had misunderstood something.
But it did come out and I did replce the input seal and the flange gasket. Will be doing the same clutch kit, tranny seal and whole deal to mine in a few days/weeks or whenever I feel like I feel like fooling with it. I use to look for things to do now I don't look 'cause I'm afraid I will see something to do.
