ground speed comparison
Dan S (NY)
06-15-2007 10:03:28
Just foolin around building a quick comparison chart of ground speeds for different tractors in the Ferguson/Ford lines of the same gerneral vintage. Does anyone have the MPH speeds in each gear at 1500rpm for the NAA 4 speed trans and the later 5 speed in the 100 series?
Comparison of ground speed MPH at 1500 RPM
gearFord 9/2NFord 8NFerguson TO20/TO30Ferguson TO35/F40
Massey Ferguson MF35/MF50
1st2.632.772.58Low .97 High 3.91
2nd3.53.563.56Low 1.46 High 5.86
3rd84.94.9Low 2.69 High 10.76
4th---10.2310.24----- -----
rev2.874.552.98Low 1.31 High 5.22
Thanks!
Dell (WA)
06-15-2007 11:20:52
 Re: ground speed comparison in reply to Dan S (NY), 06-15-2007 10:03:28
Dan..... ..its been done. A complete "chart" of tranny gears vs groundspeed for Sherman's and standard 3&4-speed trannys. The NAA 4-speed tranny gears are the same as the 4-speed 8N's. The diffy gears are 6.66:1 for all N-Tractors. The 5-speed 100's never had Sherman capability.
Check out Peterson & Beemers "Originality Guide"; IBSN #0-7603-0289-8..... ..Dell
Russ SoCal
06-15-2007 12:31:54
 Re: ground speed comparison in reply to Dell (WA), 06-15-2007 11:20:52
Except the 1952 ad brochure sez reverse on the NAA is 3.20 mph @ 1500 rpm. Is that the same as the latest of the 8Ns?
third party image
Dan S (NY)
06-15-2007 12:46:54
 Re: ground speed comparison in reply to Russ SoCal, 06-15-2007 12:31:54
Thanks for the chart Russ! Questions regarding ground speeds for these tractors seem to pop up often enough and I don't know of an easy place to find them all for a quick comparison.
Dan
