impatientance rewarded!!!!!!!
ron,ar
06-15-2007 18:51:51
Remember I said I was getting impatient about getting the old front end loader to a trial point?
Yesterday afternoon and this evening was spent plumbing the ebay lift cylinders, mounting and fabricating parts (control valve handle/linkage) and chaining down lift arms. I tied into the test port just like you guys said, made a hollow bolt for a drain/return line back thru the dipstick cover top bolt-hole and fired it up. Only had a small leak at the 3/8 union at the inlet of the control valve, but everything worked fine. Slow as you said it would be but I know my cylinders work and the control valve that has not been used for at least 20 years worked fine. I did pick up my bush hog with it for a test, slow, but still am well pleased overall. Dad would be too!!!
When finished with the RIGHT pump and plumbing I will post pictures. Thanks to a great bunch here for the help:^)
lonestarjeff
06-16-2007 08:56:57
 Re: impatientance rewarded!!!!!!! in reply to ron,ar, 06-15-2007 18:51:51
Glad to hear you got'er working again. Post pics of your "temporary" plumbing too.
Jeff
Hang in there..John,PA
06-15-2007 20:45:30
Right now I'm on happy hour.
