Order Ford 9N Parts Online
9N 3 point problem
old
06-16-2007 11:06:49
Got a call from a guy today that wants my help. Problem is I'm not a hyds man and have never been into the hyds on the N series tractors. What he did was changed has hyd oil and now the 3 point will not work, yes he used the GL-1 type oil and yes he has the PTO engaged. 3 point worked good before he changed the oil but will not now. Any ideas on what I might tell him to look at/for. I'm out of my league on this one, I'm an engine man Thanks
soundguy
06-16-2007 12:50:59
 Re: 9N 3 point problem in reply to old, 06-16-2007 11:06:49
Changing the oil might have stirred up gunk and grit in his lift sump nad could have either plugged up the orifices inthe valve.. or grit could be keeping the valve from moving in/out.
Have him manually actuate the valve a few times, and then leave it in the up position, and then start the tractor engage pto and look thru the round cover to see if he see's anything odd.
Soundguy
