Old Hokie front pump``
ron,ar
06-17-2007 14:27:26
I decided to move up here with this thread as the other one is going off page fast. I have a crankshaft pully with the threaded holes but the thing is warped bad. I do have the mount assembly that the pump sits on, but that is all I have. I have a friend that supposedly had one but it has been three weeks and he still has not found it so I guess I am back to square one and need the whole thing, pully to pump. I believe I am going to need at least a 4gpm or maybe a little larger. I know I can order the pully but D. Carpenter only lists the pully for 52 bucks and evidently does not carry the shaft, pump, and mounting hardware. I wanted to get it all at one place if possible.
TheOldHokie
06-18-2007 05:09:26
 Re: Old Hokie front pump`` in reply to ron,ar, 06-17-2007 14:27:26
That figure sounds way too high:
  1. New pulley - 41.00
  2. Splined drive shaft - $21
  3. Splined hub - 32.00
  4. Morflex coupler - 45.00
Total - $139
New SAE A mount 4GPM hydraulic pump $99
Even if you need a mounting adaptor for the pump you're only half way to your number.
TOH
ron,ar
06-17-2007 19:45:14
 Re: Try this very site! in reply to ron,ar, 06-17-2007 14:27:26
Bob, I did look at these parts, and figured out that with shipping and tax it would cost right at 500 for what I need. That is a little more than I want to spend at this time. Thanks
Bob
06-17-2007 17:28:42
Ron, this very site, out gracious hosts, YT, has the front pulley, the coupler, the shaft, the mount and the pump. Go to the link below, and scroll down.
The pulley is on another page:
http://www.ytmag.com/cgi-bin/store/model_parts.cgi?SearchArea=FORD&&md=8N&cat=Engine%20Parts&r=mcats
ron,ar
06-17-2007 19:19:11
 Re: Try this very site! in reply to Bob, 06-17-2007 17:28:42
I tried to find that on here the other day and could not locate it. I had seen it a few months ago but get lost in the ad section
Hobo,NC
06-17-2007 15:40:03
I will tell ya what you need email open, phone werks also . I would use a 11 to 12 GPM pump my self, thats what most loaders use on a N and werks great. If the loader frame doens not have a pump mount you will have to make one.
Third Party Image
Stephen(MI)
06-17-2007 15:34:58
Found this site yesterday might help you.
Redandhill.com Copy and paste below if link doesn't show up. (page of 8n hyd. parts.)
>Link
Tring to figure out what may have been on my tractor. Finding all kinds of neat stuff.
Sean (TX)
06-17-2007 14:32:46
Join the new version of the forum. Old posts get bumped to the top.. Dont have to join really..Just log in under your current handle :)
