Stuck Valve
Tex - Driftwood
06-18-2007 07:39:55
other than pouring a little MMO and letting it sit, what other suggestions do y'all have to unstick a valve?
Sean (TX)
06-24-2007 07:38:20
 Re: Stuck Valve in reply to ZANE, 06-18-2007 07:39:55
Tex - Driftwood said: (quoted from post at 09:40:17 06/24/07)
they're not that dirty at all.
Been spraying it down with MMO? Id spray some on there crank it over and spray some more on there and let it sit.
Sean (TX)
06-24-2007 05:01:09
 Re: Stuck Valve in reply to souNdguy, 06-18-2007 07:39:55
Tex - Driftwood said: (quoted from post at 17:17:34 06/23/07)
souNdguy said: (quoted from post at 07:47:03 06/18/07) Adding MMO to the oil is a good slow way to help prevent sticky valves. However.. for one already stuck.. pul the valve cover off.. id the sticky valve.. scrub the stem with an old toothbrush.. and lube it up with MMO.. or a mix of ATF and kero.. try to work it to get it moving.. once moving.. lube it up again... Add the mmo or atf to the fuel and run her.
If you can't get her moving.. time to pull head.. might be mechanical damage.. etc..
Soundguy
Hey Soundguy, how am i supposed to scrub the stem with the springs in the way?
I was wondering that too... Long bisols?
How much sluge was in there?
Tex - Driftwood
06-24-2007 06:40:17
 Re: Stuck Valve in reply to Sean (TX), 06-24-2007 05:01:09
Sean (TX)
06-18-2007 14:33:12
 Re: Stuck Valve in reply to Tex - Driftwood, 06-18-2007 07:39:55
Tex - Driftwood said: (quoted from post at 07:39:55 06/18/07) other than pouring a little MMO and letting it sit, what other suggestions do y'all have to unstick a valve?
New forum is great...Get those valves unstuck and report back with compression readings... Bookmark the thread. It gets bumped to the top when you repost.
Alan R
06-18-2007 15:21:25
 Re: Stuck Valve in reply to Sean (TX), 06-18-2007 14:33:12
Sean (TX) said: (quoted from post at 14:33:12 06/18/07)
When I had that problem, I removed the valve cover and bumped the starter while squirting PB on the stuck valve stems (along with pushing the stuck lifters back down a few times with a wooden dowel). Eventually, the valves began to follow. After a few revolutions my problem was solved (or dissolved if you will). Hopefully, your valves are not stuck too bad either and may free up as easily. Good luck. Hope you don't have to pull the head.
Sean (TX)
06-18-2007 14:29:59
 Re: Stuck Valve in reply to old, 06-18-2007 07:39:55
Anonymous said: (quoted from post at 09:37:30 06/18/07) tex, how you been doing? i tried to call you several times and finally gave up after awhile. on the stuck valve, i would alternate with pb blaster and mmo. one then the other while rotateing the engine. if its stuck really bad the head will have to come off so you can knock the valve down with a hammer and peice of wood. RP
Using the old school forum RP? You are listed as Anonymous?
Tex - Driftwood
06-18-2007 11:21:16
 Re: Stuck Valve in reply to DenN Ms, 06-18-2007 07:39:55
Hey RP! Im good. still trying to get the 47' going. Its been a long drawn out process.
I'm not real good about answering the phone when it rings. It seems like its always someone trying to sell me something. If you leave a message though, I'll call you back.
How your crops doing with all this rain?
RP-40-9n
06-18-2007 12:42:50
 Re: Stuck Valve in reply to Tex - Driftwood, 06-18-2007 11:21:16
hey tex, i will call yu. i lost half my crop to rain, and another fourth to wind, and the final fourth we have enjoyed already. RP
RP-40-9n
06-18-2007 09:37:30
souNdguy
06-18-2007 07:47:03
Soundguy
Tex - Driftwood
06-23-2007 14:17:34
 Re: Stuck Valve in reply to souNdguy, 06-18-2007 07:47:03
Soundguy
