Front axle
Red
05-14-1999 17:28:09
I know this is going to sound off the wall,but here goes. Recently I broke a left front spindle causing damage to my front axle.After roaming a tractor salvage yard for some time I approached the owner to ask for help finding the replacement part.It seems that I may have a one of a kind.My N has the radius rod holes in the L/R axles instead of the center axle as all of the diagrams at Ford/New Holland indicate. Does anyone else out there in N land have one of these too? If so what model did this come on? I thought that mine was a 46 2N but now I really wonder if this front axle assembly really belongs to a ford tractor. Thanks in advance
Mike(TN)
05-14-1999 22:36:00
 Re: front axle in reply to Red, 05-14-1999 17:28:09
That would be the correct axle/radius rod setup for a 2N. You must be looking at 8N diagrams and
parts. They would attach the radius rods to the center section of the axle.
bg
05-14-1999 20:52:09
The 9N/2N had the radius rods attached to the center axle casting. The 8N had the radius arms attached to the extensions. I agree with Mike that someone has probably switched axles sometime.
Mike(TN)
05-14-1999 22:30:51
 Re: Re: front axle in reply to bg, 05-14-1999 20:52:09
Uh...I think you have that backwards..... .
uh,...UR right....bg
05-15-1999 04:40:13
 Re: Re: Re: front axle in reply to Mike(TN), 05-14-1999 22:30:51
My synapses fired off in reverse last night. Correcto-mundo, Dude! 8N center axle, 9/2 axle extensions.
Mike H(MD)
05-14-1999 19:46:10
Red
They say a picture says a thousand words. From your discription it doesn't sound familar but someone may recognize it by a picture. It may be a 8n axle on your 2n? Good luck...Mike
