Order Ford 8N Parts Online
Hyd/ Trans oil 52 8N
Ray M
06-22-2007 07:13:17
I know this has been discussed several times before, but I'm still not sure,ok actually I'm stupid,can I use 90wt gear oil to service the trans and hyd.oil on my 52 8n? Thanks in advance.
Ray M
06-22-2007 08:03:36
 Re: Hyd/ Trans oil 52 8N in reply to Ray M, 06-22-2007 07:13:17
Thanks I really appreciate the replys, maybe I should ask the question this way , so I'll understand better, why should I not use the GL-4 or GL-5 gear oil? I'm not sure of the difference but I'm sure someone here is. Thanks
Bruce (VA)
06-22-2007 08:34:08
 Re: Hyd/ Trans oil 52 8N in reply to Ray M, 06-22-2007 08:03:36
Your pump has bronze bushings, i.e., "yellow metal". Some additives in some GL4 & 5 are corrosive on yellow metals. You can use GL4 or 5 if the label clearly says "yellow metal safe". Some is, some isn't.
Brian Bell
06-22-2007 07:24:52
90wt GL-1 (mineral oil based) gear oil is fine. This is what most folks recommend since it is yellow metal friendly.
Hope that helps
Bruce (VA)
06-22-2007 07:24:02
Tips 3 & 4 will answer your question:
http://www.ytmag.com/articles/artint268.htm
