throttle linkage question/ dell hokie
arthur ward
06-22-2007 09:41:32
dell, hokie, or anyone else with a smooth running engine.
question: what are your total outside to outside link dimensions on your linkage running directly to your governor and the linkage from governor to carb? remember, outside to outside.
the only way for me to get my idle down was to lengthen the two linkages. thus there is minimal thread holding the clasps on the rods.
thanks
arthur ward
06-22-2007 11:25:20
 Re: throttle linkage question/ dell hokie in reply to arthur ward, 06-22-2007 09:41:32
ok, that settles that. think i'll go putz around alil. then i'll try that idle mix screw for MAXIMUM rpm's.
thanks
old
06-22-2007 11:08:28
Would you believe that if you measure 10 different Ns you will most like get at least 8 different lenghts for that. They are all a little different so thats why there is the adjustment in them
Bob
06-22-2007 18:08:40
 Old... in reply to old, 06-22-2007 11:08:28
Would you believe they're NOT all adjustable? The carb-to-governor linkages on my 2 8N's are NOT adjustable, nor are the new ones you buy nowadays.
Notice the lower rod (the carb-to-governor rod) in this photo... NOT adhustable, at EITHER end.
Third Party Image
The ones sold by this are are NOT adjustable, either.
Third Party Image
"Throttle Rod - Rod, governor to carburetor control rod assembly, 8 inches long, ball recepticle on both ends. For tractors: 9N, 2N, 8N (1939-1952). (Part No: 9N9818A)"
old
06-22-2007 19:43:38
 Re: Old... in reply to Bob, 06-22-2007 18:08:40
Guess I should have siad if you have the adjustable type they are for the most part set different LOL.
Mindreader
06-22-2007 10:55:36
Yes and it has always been that way.Mindreader
