Leaky Header Connection
russ b
06-23-2007 17:52:52
I replaced my exhaust system with a unit from NAPA. It leaks around the header pipe to manifold connection. Just last night someone here was saying something about foil (aluminum?). Presumable as a gasket at the connection. I have been hoping it would collect some carbon and ...., "Tractor heal thy self".
Sean (TX)
06-23-2007 18:40:06
 Re: Leaky Header Connection in reply to Dunk, 06-23-2007 17:52:52
Bruce is right they break easy BTDT
Bruce (VA)
06-23-2007 18:37:29
 Re: Leaky Header Connection in reply to russ b, 06-23-2007 17:52:52
You probably have the clamp on upside down; check out tip # 8, below:
Link
Do not try & hold the exhaust pipe against the manifold w/ your hand & tighten the clamp. Get out your floor jack & a block of wood; put the jack under the pipe to hold it tightly against the manifold, then tighten the clamp. (Don't get carried away w/ the jack or you will bend the pipe. Or, overtighten the clamp & snap it in two. BTDT)
If the exhaust pipe flange is bent, you will never get a good seal; check it out. Also, if the manifold is badly pitted, you will have problems; get out the JB weld. If that does not work, make a sleeve from a 6 inch piece of exhaust pipe w/ the same OD as the ID of the N manifold & exhaust pipe. Dimple the N exhaust pipe 3 inches from the top to keep the sleeve from sliding down into the pipe.
Tinfoil works, but only lasts about 6 months.
russ b
06-23-2007 19:27:54
 Re: Leaky Header Connection in reply to Bruce (VA), 06-23-2007 18:37:29
Bruce, thanks for the comprehensive reply. The situation is not so bad now after giving it a few taps. There is a removal of the manifold in the future, so I will not chase perfection now.
Eventually I will want to dress up the ol thang. After 15 years ownership, just got it charging for the first time last week with help from this forum.
Thanks again to all!
Sean (TX)
06-23-2007 18:19:50
 Re: Leaky Header Connection in reply to SO WHEN WILL YOU HAVE PAI, 06-23-2007 17:52:52
Tap the clamp with hammer and tighten it some more.
Dunk
06-23-2007 18:11:13
Let me try Dell's mind reading technique...
Are you talking about exhaust/intake manifold to block?
Did you not use gaskets?
russ b
06-23-2007 18:15:23
 Re: Leaky Header Connection in reply to Dunk, 06-23-2007 18:11:13
Not manifold to block, but manifold to exhaust tube.
Dunk
06-23-2007 18:19:41
 Re: Leaky Header Connection in reply to russ b, 06-23-2007 18:15:23
third party image
Muffler Clamp
- Flanged Muffler Clamp for 8N, 2N, 9N. (Part No: FP185) $4.32
Is your clamp good?
Take a ball peen hammer and "modify" your flange till it doesn't leak, either needs more taper, or less.
Dunk
06-23-2007 18:21:33
 Re: Leaky Header Connection in reply to Dunk, 06-23-2007 18:19:41
NOTE!!!
They may be an upside down, right side up to it..
Something is pecking me in the back of the head...
Dunk
06-23-2007 18:14:17
third party image
Exhaust Manifold Gasket
- SINGLE gasket (TWO gaskets required) for exhaust manifold on 9N, 2N, 8N. (Part No: 9N9448)$2.49
Link
russ b
06-23-2007 18:33:50
 Re: Leaky Header Connection in reply to Dunk, 06-23-2007 18:14:17
Dunk, the clamp is just not too good. The manifold is rusty also. Probably time for a new clamp. In the mean time I will give it a few taps with hammer and some tightneing.
Thanks to all who responded.
