Is it a 6v or 12v, front or side distributor? The diagnostics are different, so make sure you tell us what it is. If it is a 9N, it will have a front distributor. Does the starter turn at all? If not, jump it & see what happens. Check out tip # 43 for the correct method of jumping it: Link If the starter does not turn at all, you have a dead battery, bad cables or connections, or a dead starter. It takes three things for an engine to run: spark at the right time, compression, & fuel in the right mixture. Lets start w/ spark. Remove a plug, or use an old one, ground it to the head, connect a plug wire, turn the key on & crank it. If you have a fat, bright blue spark, you are good to go. If you do not have spark, post back & you will get plenty of help. Next, lets consider fuel. Remove the bolt at the bottom of the carb, turn the fuel on & check for flow. As long as the gas is turned on at the sediment bowl, you should have a good flow of fuel. Next thing, get a can of starting fluid, remove the breather hose, turn the key on & crank the engine. After it turns over a few times, spray some fluid in the carb. Leave the choke alone! If it fires but won't start.... chances are it's carb cleaning time. Lastly, compression.....while that's not the likely problem....crank the engine & put your hand over the carb. If you feel good suction, that is a close enough compression check for the time being. Post back & you will get plenty of help!
