Head Lights
russ b
06-26-2007 12:56:41
I have found my head lamps are 12v on a 6v system. Looking around to find replacements. The 12v bulbs are GE 4411. Looks like a nominal 4" bulb (slightly larger to allow for the holder). Looks typical of the sizes available.
Couple of questions, do I want flood or spot, one of each, (only half joking}? Is there a favorite source anyone has handy?
I found this source:
http://www.replacementlightbulbs.com/lamp4515.html
Bruce (VA)
06-26-2007 15:05:03
 Re: Head Lights in reply to russ b, 06-26-2007 12:56:41
Same guy must have worked on our tractors! My 6v 1951 N came w/ both headlights & both worklights as 12v. I took them to NAPA & asked for the same model in 6v. They had both the headlights and the work lights in 6v.
Ken Crisman
06-26-2007 13:54:10
Try NAPA or Car Quest if you have one nearby . Also Dennis Carpenter has them . You probably need the 6" bulbs if they're standard . Good luck & God bless . Ken
souNdguy
06-26-2007 13:06:27
I like flood fronts.. and sometimes a spot rear worklamp. though a flood works fine.
Those tract 0 lamp holders hold a standard buld.. I'm not sure of the number.. but you should be able to find 6v bulbs for them at tsc.. 4410 maybee? been a while since I bought some..
Soundguy
russ b
06-26-2007 14:06:14
 Re: Head Lights in reply to souNdguy, 06-26-2007 13:06:27
Thanks SouNdguy. TSC has changed to Big R here in Spokane WA. I will give em a look see.
