What Does the Spark Look Like?
A. Bohemian
06-28-2007 14:28:32
Get a spark plug. Open the gap to something like 3/16" and connect one of the spark lines to it. Now clamp the loose plug up against a good grounding surface, like the engine block or similar.
Most Kettering and modified Kettering systems will throw a wide, bright blue arc across the 3/16" gap with no problem. ("Look, Ma! Plasma!")
If the spark is yellowish or a very thin line or will not jump the full 3/16", it may not be strong enough to do fire the fuel/air mixture reliably under a wide variety of conditions.
