Order Ford 8N Parts Online
8N Sleeves and Pistons
Rick Wagner
07-02-2007 14:23:55
I am working with a basket case 8N here. Already torn down when i got it. Some specs to note are, my block bores are 3.367/8?, depends on how steady i am. Old pistons are 3.268 dia measured across skirt perpendicular to pin. Old sleeves measure .047 at the very bottom of sleeve where I can still see crosshatch. I am have difficulty finding piston and sleeve combination kit. Any one have any suggestions? Thanks for the help by the way up front. Rick
russ b
07-02-2007 23:18:29
 Re: 8N Sleeves and Pistons in reply to Rick Wagner, 07-02-2007 14:23:55
When I went to the machinist with my block he didn't want to resleve it. The original job was slightly botched and he was afraid it was set in Lock Tite or JB Weld. He ended up boring the sleeves as situated in the block. I don't recall the final size or the sleve thickness, but it had to be more than 0.40. I seem to recall that the sleeves had shoulders at the top and one of the sleeves was set below the deck. If I find my paperwork.....
Hobo,NC
07-02-2007 15:40:33
You need .090 sleeves , not sure were you came up wif a .047 sleeve. Do the math If the sleeve slips in they make .002 & .005 over. you do not split the # .040's are close to .040 sum .039 sum may B .042. TOH set me straight on this and its the way they finish the sleeve, the thickness kin vary as long as the I.D. izz consistent. You do not add .90 + .090 to figger the O.D. you are only adding .040 to a .040 sleeve to git a .090 witch would make a .090 sleeve .090 bigger outside bore than a .040, think of one side only and do not add both sides.
TheOldHokie
07-02-2007 16:42:27
 Re: 8N Sleeves and Pistons in reply to Hobo,NC, 07-02-2007 15:40:33
Dang Hobo - you're makin my head swim! Yes - stock pistons and .090 sleeves for 3.367 block bore computed as follows:
  1. Piston diameter is NOMINALLY 3.1875
  2. Thin wall sleeves are NOMINALLY .040 wall thickness which means NOMINAL block bore should be 3.1875+.080=3.2675
  3. Thick wall sleeves are NOMINALLY .090 wall thickness which means block bore should be 3.1875+.180=3.3675
Adjust those nominal numbers to get a final .001 interference final fit - machine shop work.
It would appear someone has installed some sort of overbore kit that increase the PISTON diameter(and engine displacement) by using a thinner sleeve and a larger piston in a block bored for stock .090 sleeves. The block bore is spot on - right?
TOH
Dunk
07-02-2007 16:54:02
 Re: 8N Sleeves and Pistons in reply to TheOldHokie, 07-02-2007 16:42:27
Yall boys are so far over my head you look like high flyin kites.
But TOH, are you talking something like this?????
Piston and Sleeve Set - Super Piston Set For 9N, 2N, 8N Increased horsepower up to 5% by use of.0825 wall sleeve, same outside diameter as heavy wall sleeve. Can be used in any application where.090 wall thickness sleeves are used..050 wall sleeves, .0825 oversize 4-ring pistons. (Part No: PK11)
$196.84
Link
Hobo,NC
07-02-2007 17:35:00
 Re: 8N Sleeves and Pistons in reply to Dunk, 07-02-2007 16:54:02
TOH izz better at hiz goszinta's than I am, its the gosouta's that give me a fit I spec that's why I stay broke most of the time money Gos'outa my pocket to fast. Or its this Kubota spread all over the shop wif a tore up trans that bota made a real Boo Boo on. GST clutch drum came apart and wiped out sun expensive stuff, Bota knew it wuz a problem 2. I shore hope bota helps this boy out on the parts even if it's a little.
TheOldHokie
07-02-2007 18:00:03
 Re: 8N Sleeves and Pistons in reply to Hobo,NC, 07-02-2007 17:35:00
Sounds like your gosouta's are about to get hit with some heavy incoming! The man said price was no object didn't he? He better hope new tractor warranties are better than new car warranties.
TOH
Hobo,NC
07-02-2007 19:02:03
 Re: 8N Sleeves and Pistons in reply to TheOldHokie, 07-02-2007 18:00:03
He izz a blank check customer and I do look out fer'em better than I do price shoppes. I have to weed out customers and sum times if a estimate izz required I tell'em I really don't wanna werk on their trap. Bota has the parts priced so high their izz not much room fer mark up if enny. when ya git into this kin of trap you are better off let'n the customer buy the parts and make good labor, So either fix it or junk it. fer as warranty I have found Asian makes will go the extra mile to satisfi a customer over domestic makes ya never know till ya ask. I have a 96 Honda and they extended the warrant 14 years are 140K on the emissions (keep that a secret but I have the letter to prove it). Honda has been good to help out if I ask. I don't think the Asian market pays all the benefits to their employees the domestic market has to so they have the money to pay out if need B.
TheOldHokie
07-02-2007 16:57:37
Yes Dunk,
That's exactly what I'm suggesting. Seems that kite wasn't out of reach after all ;-)
TOH
teddy52food
07-02-2007 14:29:12
Sleeve thickness would be .045 for a .090 sleeve. The new pistons will be fitted to the sleeve.
THEoLDhOKIE
07-02-2007 16:34:35
 Re: 8N Sleeves and Pistons in reply to teddy52food, 07-02-2007 14:29:12
That's news to me - .090 and .040 are the wall thicknesses AFAIK.
TOH
Rick Wagner
07-02-2007 14:35:55
I am a novice on these tractors so bare with me. A .090 sleeve then ahs a wall thickness of .045? and a thin wall .040 sleeve will have a wall thickness of .020 then? Is that correct?
Rick Wagner
07-02-2007 20:11:25
 Re: 8N Sleeves and Pistons in reply to Rick Wagner, 07-02-2007 14:35:55
To Dunk and Old Okie. That kit is what I calculated I would need just with the numbers I ran. The guy I talked to said it was not, so hence the confusion on my part. This is my first tractor engine so I am moving cautiously. I really don"t want to order and bunch of stuff and then have to send it back for another try. I may go ahead and get that kit. I think it is what I am gonna need.
TheOldHokie
07-03-2007 04:12:09
 Re: 8N Sleeves and Pistons in reply to Rick Wagner, 07-02-2007 20:11:25
If the block bore measurement you provided is accurate it's dead on for stock .090 sleeves and pistons. That kit description is wacked however. It says it replaces the stock sleeves so it should work. The numbers in the description don't add up however. If the sleeves are .050 wall as stated the pistons should be .0800 over, not .0825. And it also says the sleeves are .0825 wall early on.... Makes you wonder what's going on. Personally I'd be inclined to stick with the stock .090 sleeves - I'm doubtful the performance gains from the overbore kit are worth the added expense.
TOH
Rick Wagner
07-03-2007 06:18:18
 Re: 8N Sleeves and Pistons in reply to TheOldHokie, 07-03-2007 04:12:09
That is the kinds info I need at this time. I will stay awat from the "Super" kit and run with something stockish with the .090 sleeves. My brother and I picked this thing up on the cheap side I think, and are gonna fix her and resell. I do want to do it right though, not out to gough anyone. On another question...any thoughts on the wrist pin bushings? Do they typically need to be changed on these 8N engines too? I may as well get a set if I order those pistons and such.
TheOldHokie
07-03-2007 10:33:27
 Re: 8N Sleeves and Pistons in reply to Rick Wagner, 07-03-2007 06:18:18
Off the top of my head wrist pin bushings are probably $1.50 a pop max? I'd certainly spend the $6.00. They are furnished undersize and have to be reamed to size after installation. I'd certainly do the bearings and oil pump while I'm in there as well - another $75 or so.
TOH
