Order Ford 8N Parts Online
8n Cutting out
Erik B
07-03-2007 06:39:20
Suddenly my 8n is stalling on me. I have new wires, plugs, rotor, fresh gas, good battery, gas bowl full, not sure what to check next...help?
jdchet
07-04-2007 18:22:40
 Re: 8n Cutting out in reply to Erik B, 07-03-2007 06:39:20
Points, condenser new too?
souNdguy
07-03-2007 06:43:41
Right when she stall, pul a plug wire and hold it near the block and crank over.. see if you have spark.
If so, then pull the carb drain and see if ya got fuel.
post back
Soundguy
Erik B
07-03-2007 06:51:00
 Re: 8n Cutting out in reply to souNdguy, 07-03-2007 06:43:41
Usually it restarts right up...where is the carb drain?(don't say on the carb)...
Poot
07-03-2007 07:00:09
 Erik.......... in reply to Erik B, 07-03-2007 06:51:00
where else would the carb drain be... if not on the carb? Look at the bottom of yer CARB!
souNdguy
07-03-2007 06:58:19
 Re: 8n Cutting out in reply to Erik B, 07-03-2007 06:51:00
(grin) On the carb.. Bottom that is. Should be a small plug.. shape varies depending on what tools the previous owner has used to remove it.. vice grips.. pipe wrench.. etc.
Soundguy
souNdguy
07-03-2007 06:58:10
Soundguy
