Order Ford 9N Parts Online
wrecked 9N Ford tractor
Barb Stapp
07-05-2007 09:02:04
My sweet little 1958 9N Ford tractor ran like a dream until it rolled down a hill and crashed into a tree.
The radiator is crushed along with the grill and hood. Broke the steering column. The gas tank leaked - can't tell if it's broken or what, punctured the battery. Before the battery went completely dead, it would try to start, so I think most everything else is okay.
I need advice on how to dismantle the hood and sides to get to the engine so cleanup and repair can start. This was a beautifully running tractor and once belonged to my Dad, so I am more interested in repairing than replacing it. Thanks for any help.
old
07-05-2007 10:51:26
 Re: wrecked 9N Ford tractor in reply to Barb Stapp, 07-05-2007 09:02:04
Well to be able to help we need to clear up what it is for sure. 9Ns where made from 1939-1942 and then they started makeing the 2N and made them from 1942-1948 and in 1948 they came out with the 8N and that was made till 1952. So you can't have a 1958 9N because they never made them. So to clear it up some so we can help tell use a few things. Does it have a 3 speed tranny or a 4 speed or maybe even a 5 speed. On the hood does it open all the way down the center of just a small say 1 foot by one foot door at the back of the hood?? If we know what you have we can help you a lot better since they don't all come apart the same. Also a picture helps a lot
ED-IL
07-05-2007 09:47:05
#1 - the gas tank is attached to the hood, so disconnect the fuel line from the tank - remove bolts at dashboard and doglegs by fron wheels. Then get some patience as you try to wiggle it past the steering wheel and radiator cap at the same time.
#2 - fan, water pump, distributor, coil, and such are located between the engine and radiator - those will undoubtably need some work too.
TheOldHokie
07-05-2007 11:52:51
 Re: wrecked 9N Ford tractor in reply to ED-IL, 07-05-2007 09:47:05
ED-IL said: (quoted from post at 09:47:05 07/05/07) #2 - fan, water pump, distributor, coil, and such are located between the engine and radiator - those will undoubtably need some work too.
It's amazing how well protected those components are and how much head on impact the tractor can absorb without damaging them. I'll leave it to you to figure out how I know that third party image
TOH
Dunk
07-05-2007 09:06:59
I sure would like to see a pic of a 1959 9N.
Dunk
07-05-2007 09:08:28
 Re: wrecked 9N Ford tractor in reply to Dunk, 07-05-2007 09:06:59
Err... 1958, you got me so confused I can't even type.
Dunk
07-05-2007 09:20:19
 Re: wrecked 9N Ford tractor in reply to Dunk, 07-05-2007 09:08:28
Anyhow..
Take out the bolts on the front on the hood "doglegs", take out the bolts around the dash, you may have to remove the steering wheel.
Disconnect the fuel tank line, and I think the air inlet, and make yer Ole Lady help you set the hood off.
I don't think I forgot much if anything, but don't hold me to that....
Colin King
07-05-2007 09:43:34
 Re: wrecked 9N Ford tractor in reply to Dunk, 07-05-2007 09:20:19
Or "Ole Man" as the handle might suggest ;-)
Colin
PS: Texas give you folks any rain yet?
Dunk
07-05-2007 10:08:06
 Good catch/call, Colin in reply to Colin King, 07-05-2007 09:43:34
I missed that...
Ramrod
07-05-2007 09:05:38
 Re: wrecked 9N Ford tractor in reply to Ed S. (IL), 07-05-2007 09:02:04
Barb Stapp said: (quoted from post at 11:02:04 07/05/07) My sweet little 1958 9N Ford tractor ran like a dream until it rolled down a hill and crashed into a tree.
First, tell us more, as the 9N was made back in '39, not in '58. See if you can locate the serial number, hopefully you already know it. Is it a 3 speed or 4 speed tranny? That will get us started on the correct model, the serial number will tell us everything if you can get that to us.
Ramrod
third party image
