3-point
Roy H
07-05-2007 10:16:31
When I engage the PTO anf let the clutch out I can pick up the 3-point. if I then push in the clutch the 3-point goes to the ground. I have replaced the 3 rings and honed the cylinder. Back check valve stuck in the pump or what? Any advise would help. DCR
dlplost
07-05-2007 22:08:57
 Re: 3-point in reply to Roy H, 07-05-2007 10:16:31
yes, it sounds like your safty valve is leaking.
Hitch should NOT drop just cause you push in the clutch, it should hold position.
Joe(NYC)
07-05-2007 19:26:54
If you have an N, then what you are describing is normal. The N does not have live hydraulics. I believe Mr Zane has a gizmo setup kit that will allow you to have live hydraulics.
Brian Bell
07-05-2007 12:15:11
Roy, looks like you have been overlooked so here is some info for you. See the link below. It was written by Zane Sherman. Should at least get you going.
