Order Ford 8N Parts Online
axle seals on 8n
arthur ward
07-05-2007 10:38:16
third party image
ok, i have one rear seal on my 49 in that leaks just a "tad" for the past year. i found these seals on ebay. i was told by another dealer that the cork was no longer available. they are now rubber.
which is better and is this all i will need if my hub isn't worn?
thanks
Dunk
07-05-2007 15:26:14
 Re: axle seals on 8n in reply to arthur ward, 07-05-2007 10:38:16
arthur, go thru this page. It applies to both newer, and older models.
Link
If you still have questions, ask them.
Dunk
07-05-2007 15:29:41
 Re: axle seals on 8n in reply to Dunk, 07-05-2007 15:26:14
Oh, my last ones you asked about (cork or rubber) were rubber, looked like a good deal to me.
Brian Bell
07-05-2007 12:09:55
May want to check the axle nuts and the like to make sure that they are still in decent shape. Also may want to check the brakes to make sure they are ok since you have had a gear oil leak.
