generator
oldtractor
07-05-2007 17:18:42
I just installed a used generator on my N. The ammeter reads "0" when I start and run the engine, then drops into negative territory when I turn on headlights. A multitester clipped to anything hot goes haywire even without grounding the other lead of the tester. What"s going on here?
JoePilot
07-06-2007 10:01:39
 Re: generator in reply to oldtractor, 07-05-2007 17:18:42
Probably need to polarize the genny. I can never remember the specifics, but search for "polarize" in the archives and I'm sure you'll find lots of info. It is also in your repair manual. No manual? First link on the left border will let you buy one. Highly recommended.
Joe
dan hill
07-06-2007 04:25:29
Ammeter says no charge, no need for a voltmeter.Always connect negative or ground lead of meter first.Old vtvm meters will swing up scale if you touch the probe on low ranges.
Tom N MS
07-05-2007 17:20:48
Got to use an analog meter. Digitals go crazy like that.
