hood
rugclnr
07-08-2007 08:57:57
Trying to remove hood. Have removed 4 bolts on dash and 2 on crosspiece by gas tank. Hood will not budge. Have I missed something?
kcred
07-08-2007 21:41:52
 Re: hood in reply to rugclnr, 07-08-2007 08:57:57
Naw , one man job to remove hood after you take out the bolts on the dog legs, Hang Two come-alongs from rafters over the hood, put rope under the back of the hood and one around the head lights and work one at a time, slow. Red
Well...John,PA
07-08-2007 18:05:17
If'N it is a 9N you are working on, you will probably have to remove the steering wheel too.
Dunk
07-08-2007 09:22:06
Remove your gas line too.
Dell (WA)
07-08-2007 09:14:18
rugclnr..... ...putt'chur gastank crosspieces back in. Gastank comes out with the hood; its a 2-person job to remove because it is so awkward. I had my 9yo son help, it ain't heavy iff'n gastank is semi-empty.
Now remove the two bolts at the bottom of yer doglegs above yer front axle and catch yer grill as you loosen them. Lift over radiator neck as you stumble foward and place on saw horses. Simple, eh?..... ....Dell
crazy8
07-08-2007 09:13:15
remove the bolts on the dog legs.
