Order Ford 8N Parts Online
Will a 8N oil pan fit a 9n?
RJ
07-08-2007 17:58:09
Hello I just bought a fair 1940 9n, the engine pan has been brazed a few times thru the years and still seeps oil, I can get a perfect pan local from an 8n, it looks the same bolt pattern but I'm not sure about the size on the crank seals, Thanks for any help!
souNdguy
07-09-2007 06:19:50
 Re: Will a 8N oil pan fit a 9n? in reply to RJ, 07-08-2007 17:58:09
It probably leaks cuz the prev owner was lazy and brazed it in place, and full of oil.... Once you drop it, burn the oil out of the joint with a propane torch.. remove the old buggered up brazing, and rebraze or silver solder,both sides if need be.. and keep it for a spare.. paint her up so she don't rust...
Soundguy
Dell (WA)
07-08-2007 19:24:50
RJ..... ...yes, according to my N-Ford MPC, the oilpan, p/n: 9N6675, fits all flathead engines from 1939 9N thru 1952 8N. Ain't you lucky?..... ...Dell
YES...John,PA
07-08-2007 18:02:43
To the best of my knowledge, the oil pans are interchangable. HTH. John,PA
