Order Ford 8N Parts Online
Hi speed roadgear on 8N
rgprobert
07-09-2007 08:02:22
How common are these roadgears? Any own any and have problems? Which tractors did were they installed on?
offroadr
07-11-2007 07:41:27
 Re: Hi speed roadgear on 8N in reply to rgprobert, 07-09-2007 08:02:22
So if 4th is the road gear whats the level on the right under the steering wheel?
Dell (WA)
07-09-2007 18:25:22
Robert..... ..what we have here is a "failure" to communicate. (grin)
Roadgear in the 8N is 4th-gear. (its even labeled 4, between R and 1, isn't that amazing?) It has a maximum roadspeed of 15.47mph at full throttle.
Howsomevers; don't get confused with the dealer installed Sherman auxiliary tranny with shifter lever over yer left-toe. The Sherman tranny in OverDrive will hustle yer 8N down the road at a speedy 23.12mph. Be certain to keep yer mouth closed 'cuz buggs on yer teeth taste blattzs. (grin)..... ..Dell
Bob Harvey
07-09-2007 17:42:38
Do you have a Sherman aux. transmission add-on ?
Ross Pugh(NC)
07-09-2007 08:26:38
All 8N's came with a 4 speed transmission. 4th gear is yer road gear.
jdchet
07-09-2007 14:23:04
 Re: Hi speed roadgear on 8N in reply to Ross Pugh(NC), 07-09-2007 08:26:38
4th gear is for strolling down the "country lane" with your N! :-)
Ross Pugh(NC)
07-09-2007 14:35:25
 Re: Hi speed roadgear on 8N in reply to jdchet, 07-09-2007 14:23:04
jdchet, pull that lever under yer steering wheel on the right side all the way down on mine and that is "rrrolling" ant not 'strolling'. Maybe someone needs to work on yours.
