Rotating Exhaust Valve Installation
Rod (La)
07-09-2007 08:07:36
I am in the process of putting my engine back together. I got the new intake valves installed with no problem using my "C" type spring compressor. Now the exhaust is a different story. I tried it with everything assembled and without and just cannot get it all in there at one time. I know there has to be a way, but I have yet to figure it out. If anyone has a blow by blow on how to do this, It would be greatly appreciated.
Thanks,
Rodney
Hobo,NC
07-09-2007 10:19:49
 Re: Rotating Exhaust Valve Installation in reply to Rod (La), 07-09-2007 08:07:36
third party image
Install as a asy, use bent tip screwdriver go threw exhaust port push guide down install guide horse shoe shaped retainer.
Rod (La)
07-09-2007 11:38:56
 Re: Rotating Exhaust Valve Installation in reply to Hobo,NC, 07-09-2007 10:19:49
Thanks Hobo, that is just what I was needing. I had thought about going about it that way but I told myself it would not work before I even tried it. Just last week I saw a big screw driver out in the middle of the road and stopped and picked it up. It will be just perfect for this. Thanks again.
Rodney
Hobo,NC
07-09-2007 10:21:23
third party image
Bent tip scredriver
Jack-Illinois
07-09-2007 09:26:08
third party image
Old valve tools for "L" head engines
Blue Point CF49 valve lifter
Blue Point CF-7 keeper holder
These are the ones my father used on his '51 8N back in the 1950's Worked just fine too!
