Limiter Chains Top Link Hookup? 2N
Rusty 2N
07-09-2007 08:15:38
Ok,I looked at that post below on the 2" reciever & like the idea. although I need to maintain the drawbar heighth so was thinking about chains. I have a 3 hole top link attachment & was wondering if the downward pressuer from the weight of trailer would effect or dammage the operation of the hyd system if I hooked the chains to the middle hole? I presently have two bars that go from the bottom hole to the drawbar that hold it in one postion & lock it level, but can't raise it. Would like to beable to raise the front of trailer to make unloading rocks,dirt,etc easier. Also if anybody needs rocks I can surely set you up at a real good price. thank you for any adise here. Rusty
Rusty 2N
07-09-2007 11:41:13
 Re: Limiter Chains Top Link Hookup? 2N in reply to Rusty 2N, 07-09-2007 08:15:38
Thank you for your replies. The longer pins/bolts was my second option on this one. I also should let the coffee do it's job before getting to excited about a project. Have to run to the parts house in a bit so will get one then. Thanks again. Rusty
Jack-Illinois
07-09-2007 08:33:43
I must be missing something?? You are going to have to take the bars off to use the chains, so why not just put the chains in the bottom hole where the bars were?
Rusty 2N
07-09-2007 09:09:42
 Re: Limiter Chains Top Link Hookup? 2N in reply to Jack-Illinois, 07-09-2007 08:33:43
Because the top link is going to the bottom hole.
souNdguy
07-09-2007 11:17:41
 Re: Limiter Chains Top Link Hookup? 2N in reply to Rusty 2N, 07-09-2007 09:09:42
Just use a longer pin.. that's why they make em' in different lengths...
Soundguy
Jack-Illinois
07-09-2007 10:15:23
Yep - sorry didn't have brain engaged yet. Guess the coffee kicked in and I see it real plain now.
BillM (OH)
07-09-2007 09:36:54
I've only got a 1 holer, so limiter chains and top link all go on the same pin in it. Should fit on one pin on yours as well.
