Draft control
Roy hedlund
07-09-2007 09:05:23
How does the draft control rod connect inside or does it? is it a ball and socket? Pin, bolt, or other? Mine has a round small ball @ the end of the rod.I can rase and lower the 3-point unit but if I push in the clutch the PTO will stop and the 3-point comes down.If the clutch disengages the PTO is there not a back check valve to keep the 3-point up? 8/9-N
Bob Harvey
07-09-2007 17:44:14
 Re: Draft control in reply to ZANE, 07-09-2007 14:26:13
YOIKS !!
Rusty 2N
07-09-2007 09:17:39
 Re: Draft control in reply to Roy hedlund, 07-09-2007 09:05:23
If your 3 point lowers when clutch is in or tractor is off then you are losing hyd pressure some where. remove right side plate where dipstick is & run tractor & look for bubbles around hyd. pump or fluid draining out of lift piston. Things will be spinning in there so no need to stick you hands in there. It will be obvious to the eye. Good luck, Rusty
