Hi all! I finally got my '47 8N S/N 2185 home and began working on some of the problems. I replaced a cracked and warped exhaust manifold and gaskets (rearmost brass nut was stripped)but I was able to stop the leak with just a new gasket as there was not too much block erosion.I replaced the plugs, cleaned the sediment bowl and put in fresh fuel adjusted the carb and it runs fine. Hydraulics seem good too. The big problem is with the brakes (or lack thereof). When I got the tractor home hydraulic fluid was dripping out of the axles and in checking the fluid level I found it was really high. I sucked about 2 gallons out which brought the level down to the full mark on the dip stick. I have ordered brake parts for a complete rebuild on both wheels (less drums) and I'm wondering if there is any kind of ideosyncracy that I should be aware of.I have the manual. I am aware that the splines need to be sealed with something like silicone to be sure that fluid doesn't get to the brakes again. I have absolutely no pedal on the right brake and almost nothing on the left. In looking at the left backing plate it appears as though at one time the brake shaft was deflected enough to put a pretty serious semicircular dent in the plate which I think I can probably straighten by hammering it flat. That brake does grab occasionally but has shoe contact to allow it to function to small degree. The biggest problem I can forsee is handling the wheels and tires and since I'll be working outside I have a tree I can lean them against. Anyone have any advice or suggestions to offer before I dive into this phase? By the way, thanks to all of you who provided input for my exhaust leak. Art in Cortez, Co.
