Suddenly started breaking shear pins
Kenster
07-09-2007 17:21:46
One more thing under the "It's always something" category.
Got my new sway bars and the shredder attached and headed for the seven acre meadow. I made one long pass, did a slow left turn, and my shear pin broke. This was an oversized bolt that the previous owner had left in there. Probably thicker guage than it should be. I drove back to the barn and pulled another pin out that I had bought last year "just in case." It broke within seconds of hitting the grass, which is only about 18 inches high. I've plowed through shoulder high weeds and two inch saplings and never broke a pin before. I tried to think what would be causing it. I pulled both bolts in the hog's tranny. Even from the bottom hole I couldn't feel any fluid so I filled it up til it trickled out the bottom hole. Does that sound right?
The third shear pin lasted about 15 minutes and broke in 12 inch high grass.
I don't get it. The only thing different from the last time I mowed is a new PTO shaft and ORC.
Thoughts?
Kenster
07-11-2007 15:03:42
 Re: Suddenly started breaking shear pins in reply to arthur ward, 07-09-2007 17:21:46
WAYNE2 said: (quoted from post at 17:31:35 07/11/07) Never mind gahor-get it figured out? Wayne
Hey, Wayne. Well, I'm not real sure what was causing it. I did heavily grease up the telescoping drive shaft on the hog. It seems like it might have been snapping the shear pins when I raised the implement all the way up, which perhaps forces the inner shaft (the half that connects to the tractor) all the way in and against the pin.
The new ORC is exactly the same length as the old one, and the new PTO shaft, I assume, would be the same as the old one. So I don't know why a change in length would be an issue.
Anyway, I bought a half dozen 3/8 x four inch bolts. Put one of those in this morning and mowed for four hours without breaking a pin.
WAYNE2
07-11-2007 14:31:35
 Re: Suddenly started breaking shear pins in reply to Kenster, 07-09-2007 17:21:46
Kenster
07-10-2007 09:44:21
 Re: I thought this WAS the N forum. in reply to Kenster, 07-09-2007 17:21:46
I had replaced my tractor PTO shaft (not the hog's shaft) with a new one. I had replaced my old ORC with a new one.
The hog shaft is telescopic. It slides in and out to hook up to the tractor.
Basically, self adjusting so How could it be too short or too long?
Not arguing, just trying to figure this out.
The blades seem to be spinning free and clear with no problems
If it is binding, where should I look for this?
By the way, many of us post an issue in more than one web site. Lots of us frequent multiple boards. Many only haunt one board. Posting questions in more than one forum helps to get a larger variety of replies and suggestions.
gahorN
07-10-2007 03:33:19
I thought this was the N forum. No?
If I could find the reply you posted somewhere else then I"d have enjoyed this topic too. (and I"d cut/paste it for others also.) ;Þ
souNdguy
07-10-2007 06:12:07
 Re: I thought this WAS the N forum. in reply to gahorN, 07-10-2007 03:33:19
he's refering to the n-tractor clb forum.. as there was a duplicate post over there..
Soundguy
Dean
07-09-2007 17:39:58
Kenster:
See my reply to your identical question in the N board forum.
Dean
