Order Ford 8N Parts Online
8N Right Brake Pedal
8N Kelly
07-10-2007 10:57:37
I need to replace the right brake pedal on my 8n? What's the easiest way?
souNdguy
07-10-2007 11:26:19
 Re: 8N Right Brake Pedal in reply to 8N Kelly, 07-10-2007 10:57:37
The easiest way is to probably hire it done.. course.. that's the most expensive way to.
What's wrong with the pedal that you want it replaced? Cosmetic issue, or did it break?.. etc.
if broke.. i think I'd weld it and then gusset it up.
Otherwise plan on disassembling r-side brakes.. also.. if it is like the pedal on the hundred series.. it is keyed to the shaft it rides on.. etc..
Soundguy
8N Kelly
07-10-2007 11:38:07
 Re: 8N Right Brake Pedal in reply to souNdguy, 07-10-2007 11:26:19
The inner inch or so rusted away and then the guy I bought it from welded a small metal replacement piece onto it. The left brake pedal and the clutch are the same way but seem pretty easy to replace. I guess the real problem is where the left and right pedals come together, there is a pretty good size gap. My foot can nearly go through. I have the diagram in the shop manual and have Googled a bit but am not finding an easy solution.
souNdguy
07-10-2007 11:47:36
 Re: 8N Right Brake Pedal in reply to 8N Kelly, 07-10-2007 11:38:07
Hmm.. I'm not sure i have ever seen that amount of rust on any of the foot pedals.. that they would actually diminish that drastically in size..
Still.. if it were me.. i think I'd weld them up and then grind them to look pretty..
( I've been called 'cheap' before.. though... )
Soundguy
wayne2
07-10-2007 22:08:16
 Re: 8N Right Brake Pedal in reply to souNdguy, 07-10-2007 11:47:36
Cheap !!! Have you ever used bailng wire or shimmed with beer can alum???? Wayne
souNdguy
07-11-2007 04:51:19
 Re: 8N Right Brake Pedal in reply to wayne2, 07-10-2007 22:08:16
I'm guilty of both of those.. as well as using old inner tube and cardboard box as gasket material!!
Soundguy
wayne2
07-11-2007 05:42:04
 Re: 8N Right Brake Pedal in reply to souNdguy, 07-11-2007 04:51:19
An old felt hat fits the bill also!!!
souNdguy
07-11-2007 05:54:13
 Re: 8N Right Brake Pedal in reply to wayne2, 07-11-2007 05:42:04
Ya got me on that one.. I've never used one like that.
Soundguy
Wayne2
07-11-2007 10:30:10
 Re: 8N Right Brake Pedal in reply to souNdguy, 07-11-2007 05:54:13
Used it to rebuild a 22 Ford- Wayne
