Draft Control Rod
Roy Hedlund
07-11-2007 07:34:39
How does the end of the Draft control rod connect inside the unit or does it? Does it sit in a saddle? is it a ball and socket?,snap ring?,pin?, or other? On the one I have it looks to be some what of a round small ball @ the end of the rod. with out draining some of the oil out it is not visible. I can feel what I think is a half round type saddle the rod sits on. How about some help on this.
Poot
07-11-2007 08:33:15
 Re: Draft Control Rod in reply to Roy Hedlund, 07-11-2007 07:34:39
I believe what you are describing is the control "arm"... yes, it just sits in there & connected only at the top.
Roy hedlund
07-11-2007 08:51:46
 Re: Draft Control Rod in reply to Poot, 07-11-2007 08:33:15
Thanks for the info
souNdguy
07-11-2007 07:53:41
Are you talking about the plunger rod with fine threads that fits with the big draft spring for 2n-8n-NAA???
What's the exploded diagram in your master parts catalog show you?
soundguy
Roy Hedlund
07-11-2007 08:58:45
 Re: Draft Control Rod in reply to souNdguy, 07-11-2007 07:53:41
Thanks, Poot got it,control arm.
