a little more aggressive
arthur ward
07-11-2007 17:27:29
third party image
Well I got these new(old)shares put on a little while ago. They are far more aggressive than what I had on there. I am not sure but I think that with them hanging over a couple more inches to the rear of the old ones that I may have to change my angle of attack when plowing. I tested them with the back of the landslide set about 1.5" higher than the front point. They slowed the tractor down more than the old shorter shares. Plus the old shares were NOT rock shares(no point on them). Definately a different animal. Anyway, here is a pic of them and the second pic is when I just got done testing them.
Colin King
07-12-2007 07:44:34
 Re: a little more aggressive in reply to arthur ward, 07-11-2007 17:27:29
Arthur,
Do you have an Oliver part number for that share? I was told by my local shade tree tractor mechanic that with a little tinkering there are JD shares that will also fit on the Dearborns and Fergies, but I haven"t had a need to try.
Colin
PS: Nice looking garden you"ve got! You must have a bit longer growing season there.
arthur ward
07-12-2007 09:01:41
 Re: a little more aggressive in reply to Colin King, 07-12-2007 07:44:34
third party image
Colin, yes these are oliver shares. They are almost a perfect fit. I have to tink with the bracket holes in back of the moldboard a little bit so that I can close up that gap. I guess there are some JD shares that can fit also if tinkered with.
EastCentral Wisconsin here. Not a long growing season. Thanks
RS 00 14
Colin King
07-12-2007 09:13:21
 Thanks! in reply to arthur ward, 07-12-2007 09:01:41
Hey, thanks for the info!
Colin
Dell (WA)
07-11-2007 19:27:27
Arthur..... ..pay attention to yer share's "GAP". There should be NO GAP. You may need to "loosen" and "tap" both yer new share and yer "shin". They should fit "flush" against your moldboard..... ..Dell
arthur ward
07-11-2007 19:36:42
 Re: a little more aggressive in reply to Dell (WA), 07-11-2007 19:27:27
hi dell
that is the closest that i can get it without ovaling that bolt hole on the bracket behind the mold board. i did tap it up as close as it would go. they are not a perfect fit but to get a new set of hardened rock shares for $12...well i cannot complain.
tomorrow is another day and hopefully i will get time to correct it. i really think that i may have to shorten the rear of those shares some but i have to test it some more.
arthur ward
07-11-2007 17:28:42
third party image
just done testing them, oh, that is part of my big garden!
Indiana Jones
07-11-2007 18:39:32
 Re: a little more aggressive in reply to arthur ward, 07-11-2007 17:28:42
Those plow bolts look loose. Have you checked them?
Dunk
07-11-2007 17:31:28
I don't think you are going to make much headway plowing that concrete slab...
TheViperr
07-11-2007 17:52:45
 Re: a little more aggressive in reply to Dunk, 07-11-2007 17:31:28
I need a set of them tires!!
arthur ward
07-11-2007 17:54:17
 Re: a little more aggressive in reply to TheViperr, 07-11-2007 17:52:45
$168 plus tube and install. Local county co-op.
