Rattzie..... ..congratts on yer successfull splitt; see 'nuttin' to be afraid of, was itt? Pay attention to your clutch splined hub. It is NOT symmetrical but "off-sett". Long side to tranny. Understand? Now you need to "center the clutch". Use the tranny input shaft. 4-bolts and its out. And replace the tranny input seal $3 (cheap) at the same time. I always "de-polish" the clutch rubbing surfaces of both the flywheel and the pressure plate with coarse sandpaper. Don't mucka'round worrying about worn-in grooves and scratches, leave'em. Tractor clutch engagement is so coarse, it don't matter. While it is always a good thing to "mark" mating parts with punch-pricks so you can re-install them "balanced"; don't worry about it. Install yer clutch pressure plate with the "shouldered" 5/16" bolts, torqued to 18ft/lbs. NO WEDGIES needed. Generally the pressure plate doesn't need replacing, but "inspect the 3-fingers for "wear"; that'll tell you iff'n needs replaced. Also "inspect" yer flywheel starter teeth for wear. NO SHARP EDGES, ok?..... ....HTH, Dell
