Whats it worth?
russ b
07-12-2007 07:36:44
How much is this something like this worth?
older 6 foot ford disc front row notched blades, rear row smooth blades, good shape 3pt.
I was thinking $500, the asking price.
Brian Bell
07-12-2007 17:36:16
 Re: Whats it worth? in reply to russ b, 07-12-2007 07:36:44
I bought a Dearborn 11-135 "flip-disc" a few months ago for 350.00. It will get the front end of my 8n off the ground as it is with no extra weight. It cuts good and deep. Can unbolt and flip the back 2 gangs up on the front to get extra cutting weight. I thought I got a good deal considering new discs that are made much cheaper go for 2 to 3 times more!
James Rader
07-12-2007 20:19:28
 Re: Whats it worth? in reply to Brian Bell, 07-12-2007 17:36:16
I have a dearborn that looks nearly identical to Hobo's other than mine is red and has a telephone pole wired on it for weight. Bought it several years ago for $100.
Now I feel like I got a great bargain...
James
Ross Pugh(NC)
07-12-2007 14:11:59
I paid $300.00 for mine. It has angle adjustment on the discs.
Erik B
07-12-2007 12:29:57
I found one very similar, a Dearborn, for $350. It's a 6'. No paint, but intact, no damaged discs...
arthur ward
07-12-2007 11:22:07
russ, if you are selling and are around wisconsin somewhere...i would be very interested in a price. i have been looking for one for a year now.
email me if selling.
8N'r--WI
07-12-2007 09:05:57
Russ---are you buying or selling?
Tim
Hobo,NC
07-12-2007 08:54:49
third party image
$500 will not buy this one
Lumpy
07-12-2007 19:51:49
 Re: Whats it worth? in reply to Hobo,NC, 07-12-2007 08:54:49
Hobo, I'm with ya! I got a 7ft Dearborn just like this one. One of the best cut'in disc's I have ever used. I was offered $750.00 in bill's and turned it down. My 861 and this disc make a excellent combo.
Ross Pugh(NC)
07-12-2007 14:19:31
 Re: Whats it worth?/HEY HOBO in reply to Hobo,NC, 07-12-2007 08:54:49
Hey, Hobo, you better get that solar panel covered up, before it blisters in this hot sun. (grin) Don't that disc lift the front end off the ground? It looks a lot longer than mine, and it makes my front end light.
Hobo,NC
07-12-2007 14:54:05
 Re: Whats it worth?/HEY HOBO in reply to Ross Pugh(NC), 07-12-2007 14:19:31
third party image
Its a dearborn and just rite fer a N. This one izz a lienback or how ebber you spell it and will lift the front end wif all the weight added to it.
Ross Pugh(NC)
07-12-2007 15:45:06
 Re: Whats it worth?/HEY HOBOYER DISCS in reply to Hobo,NC, 07-12-2007 14:54:05
Hey , Hobo, it looks like you have the smoothe discs in the front and the notched on the back of that one. I was alaways told the notched discs go in front to cut up the stalks and other trash before the smoothe discs push them together in front of the discs. The discs with the notches holds the trash down and cuts it up before the smoothe ones get it. Of course I may be wrong, but it makes sense to me. You may have notched on the front also, I can't tell very well from the picture. I'll bet that one does make you steer wif the brakes if ye lift it. I finally got about 1/4" of rain last evening, Maybe that will help save my corn that is just now tasseling.
Hobo,NC
07-12-2007 16:46:26
 Re: Whats it worth?/HEY HOBOYER DISCS in reply to Ross Pugh(NC), 07-12-2007 15:45:06
All of'em are notched. I put up 300 ears saturday, and turned the field over to the vouchers (kin folk) to have at it.
RP-40-9n
07-12-2007 07:46:29
russ, depends a lot on where you are located. i got one last year for 350, im in central tx. RP
8N'r--WI
07-12-2007 14:54:51
 Re: Whats it worth? in reply to RP-40-9n, 07-12-2007 07:46:29
RP--right you are---here is one that went for less than $200 a few weeks ago on Ebay in OHIO.
Ebay # 110140111441
This would go for $400-$600 in WI if you could even find one.---Tim
Colin King
07-12-2007 07:46:24
That's about what I've been seeing around Central Minnesota.
Where're you at? I'm in the market for one of those.
Colin, MN
russ b
07-12-2007 08:03:17
 Re: Whats it worth? in reply to Colin King, 07-12-2007 07:46:24
I will try to post a picture and give a rundown after I look at it.
Regards, russ
