The short answer is no. Take it off & check resistance. A 6v coil should have 1.5 ohms & a 12v coil will have 3 ohms. Phil posted the 'long answer' a week or so ago: All ignition resistors are not EQUAL and Front Mount Coils will not Mix/follow Automotive Specifications. The Rule of Thumb for a Front Mount Starts with the OEM Ballast Resistor. This is a PTC device that Limits current to the required 3 AMP max thermal load. This Protects your COIL! A) The OEM Ballast is the Only Resistor required for OEM 6V coils operated on OEM 6 Volts. Those PPL that use Ceramic Devices as a substitute will suffer Under and/or Over Current. B) The OEM Ballast is the Only Resistor required for 12V Coils operated on 12 Volt Systems, these have a "Pure" resistance value of 3.0 Ohms (-.5 to + .25) or dry rated @ 2.5 -3.25 ohms C) The only 12V coil that does not use the OEM ballast is the 12V coil that has a "Pure" Resistive value of 4.0 Ohms @3 Amps Automotive Ignition Resistors do NOT Operate or function the same as the original OEM Ballast. If you use these you will have UNDER and/or OVER current conditions. The Automotive industry uses both PTC (positive temperature coefficient), and NTC (negative Temperature coefficient), and Fixed resistive devices. These are designed to function with the side mount Coil (more than)> 4 amps If you want to use an OEM 6 Volt coil on a 12 Volt system the OEM Ballast MUST have an additional resistor. This Resistor value can be an Automotive Type (fixed) of ~ 2.25 Ohms rated @25 watts or made from RAT Shack Resistors with Equivalent Wattage ratings. The challenge is meeting the Wattage rating. The solution may look Ugly ( 2 R’s in series or Parallel) but function is important The conclusion: Use the OEM Ballast in ALL cases. If the OEM Ballast Burns out you will need to add Resistance but the OEM Ballast must be Part of the Circuit with only one exception. I hope that Helps, BTW: Measuring Coil resistance will depend on current(heat). The OEM 6V coil meaures .64 ohms (dry), .76 ohms @ 2 Amps, and .98 ohms @ 3Amps. The value to use is .98 or 1.0 Ohm
