exhaust valve; which is the correct one?
paulgvilla
07-12-2007 10:29:02
The #1 exhaust valve in an 8N was bent. I purchased several different exhaust valves, but none fit. On the original valve, the stem was milled up to about 1" from the head. The stem on the new valves are milled up to the head. Because of this, the parts that slide over the stem do not fit. Can someone explain why this is so. I have the manual which does not address this situation.
Thanks.
