Order Ford 8N Parts Online
9N, 2N, and 8N compression
Sam F.
07-13-2007 12:06:06
What should be normal compression on the N series ?? Are they all different, the 8N, 2N, and 9N ??? Thanks
Ross Pugh(NC)
07-13-2007 13:05:37
 Re: 9N, 2N, and 8N compression in reply to Sam F., 07-13-2007 12:06:06
The I&T FO-4 Manual says minimum compression pressure is 90psi(620kPa). The lowest pressure reading must be within 75 percent of the highest. A greater difference indicataes worn or broken rings, leaking or sticking valves or a combination of these problems.
Sam F.
07-13-2007 13:13:33
 Re: 9N, 2N, and 8N compression in reply to Ross Pugh(NC), 07-13-2007 13:05:37
I have 3 at 85 pounds and 1 at 110. Have not tried squirting a little oil in each cylinder to see if that helps raise compression or not. Tractor had been sitting for 2 years and had only run about 5 minutes before I did compression test.
Bruce (VA)
07-13-2007 15:50:28
 Re: 9N, 2N, and 8N compression in reply to Sam F., 07-13-2007 13:13:33
After setting 2 years, the rings could be stuck. Put a tablespoon of MMO or ATF in each cylinder & let it set for a few days.
Colin King
07-13-2007 12:16:58
They should be the same and between 120psi-90psi.
Colin, MN
