Order Ford 9N Parts Online
Some more pics of the 9N
RJ
07-13-2007 19:48:46
third party image
A pic of the cast iron dash, the oil gauge is really old, key and starter button in dash, the speaker magnet sticks great.
James Rader
07-15-2007 18:20:01
 Re: Some more pics of the 9N in reply to RJ, 07-13-2007 19:48:46
Wow, learn sumthin everyday... It is very simular to the cast aluminum dash in looks and structure. I think it would be a reasonable guess that this could be a mid stream change between the early 9N aluminum (easily cracked) dash and the most common steel plate dash. Thank you for sharing the extra photo's, It's great finding out something new about the N's.
James
Ross Pugh(NC)
07-14-2007 17:00:51
I've got a 1947 2N that has the same dash layout as yours. Yours may be a 2N also.
Peter, Covington, LA
07-14-2007 12:30:59
Besides my 9N I have a Model T Ford. The engines are remarkably similar, although they were made several years apart.
With Model T's, the engine's serial # was stamped on a flat place similar to the one you show. But when a replacement block was shipped from the factory, it had no serial number stamped on it. The shop that replaced the block was supposed to stamp the same number on the replacement block as the original block.
It seems reasonable to me that Ford used the same arrangement with replacement blocks for tractors. And, if the shop that did the replacement, or the farmer who did it himself, had no number stamps, there wouldn't be any number at all on the block.
Could this be the answer??
Hobo,NC
07-14-2007 17:24:13
 Re: Some more pics of the 9N in reply to Peter, Covington, LA, 07-14-2007 12:30:59
You could b rite I never thought about it that way, I have a 46 2N serial # stamped on a side mount block.
Sean (TX)
07-13-2007 21:16:40
 Re: Some more pics of the 9N in reply to lonestarjeff, 07-13-2007 19:48:46
Wrong! The Early N's had studs and nuts... Not bolts...
RJ
07-13-2007 22:37:53
 Re: Some more pics of the 9N in reply to Sean (TX), 07-13-2007 21:16:40
Im not sure which bolts your talking about? the head are studs and nuts.This being my 1st tractor, im very much a rookie, but love oldies. My oldest truck is a 1935 Diamond T...
arthur ward
07-13-2007 21:09:17
its been rebuilt at least once. head bolts are not bolts. thats the easy way of not having to take off the hood and tank to get the head off.
also, i think i would clean out that sediment bowl.
RJ
07-13-2007 22:23:01
 Re: Some more pics of the 9N in reply to arthur ward, 07-13-2007 21:09:17
Yes the bowl was cleaned the day before, I took out the screen and put a filter inline until the tank dumps its old crud, it's not rusty inside but lots of old build up. Todays 10% alcohol gas lifts off the old crud and thats what its filled with.
Sean (TX)
07-13-2007 21:07:38
 Re: Some more pics of the 9N in reply to LyleSch, 07-13-2007 19:48:46
RJ said: (quoted from post at 22:48:46 07/13/07) A pic of the cast iron dash, the oil gauge is really old, key and starter button in dash, the speaker magnet sticks great.
[img]http://i50.photobucket.com/albums/f329/luciferthedog/aaa006.jpg?t=1184381539[/img]
Looks like my dash. My starter button is in front of my gear shifter... Spray some paint on the serial # and see if that helps. Wire brush it first.
third party image
third party image
Sean (TX) 9N79052
third party image
RJ
07-13-2007 19:53:08
third party image
another of the iron battery shelf. What makes a good gasket for the air cleaner jar?
ED-IL
07-13-2007 22:02:36
 Re: Some more pics of the 9N in reply to RJ, 07-13-2007 19:53:08
is that a rubber hose fuel line???
That aint original.
RJ
07-13-2007 19:55:41
third party image
The other end of the pipe.
RJ
07-13-2007 19:58:54
 Re: Some more pics of the 9N in reply to RJ, 07-13-2007 19:55:41
third party image
The unknown, comfortable, butt ugly seat. is that a pun?
RJ
07-13-2007 20:01:38
 Re: Some more pics of the 9N in reply to RJ, 07-13-2007 19:58:54
third party image
Rusted beyond reading. But it must be close to a 40 year tractor.
