Order Ford 9N Parts Online
2N/9N fronts wheels...
2N new guy
07-14-2007 09:24:48
Hi guys
I'm trying figure out the difference between the2 new aftermarket wheels that are offered. I know it SAYS 19x3 & 19x4 but are they really different? I've seen 19x3 all over place but only here have I seen the 19x4 offered...and prices are all over the map. $75 to $125.
Really like to get 19x4 for a wider tire. Also does anybody offer or do you know who manufacturers a 19x4 bare rim blank? Anybody the inside diameter of the hoop? If anybody can help that'd be great. This is my first 2N and I'm a little confused. I'm just using it for putting around the ranch but do have some really soft spots in the back 40. Thanks!
Dell (WA)
07-14-2007 09:43:57
 Re: 2N/9N fronts wheels... in reply to 2N new guy, 07-14-2007 09:24:48
third party image
Neubie..... .the traditional rim for the 2N is a 5-bolt widehub 3x19 rim with 4x19 tire ($50). The "new" 4x19 widehub rim would mount a 6x19 tire ($100)
You might find "free" 19" used tires for the modern small-spare at junkyard, or used 19" motorcycle tires that would meet yer "flotation needs. Yer call..... ...Dell
arthur ward
07-14-2007 16:50:54
 Re: 2N/9N fronts wheels... in reply to Dell (WA), 07-14-2007 09:43:57
damn dell, i never thought about using motorcycle tires for the front.
wonder how they hold up on the sidewalls with the weight.
Dell (WA)
07-14-2007 19:24:28
 Re: 2N/9N fronts wheels... in reply to arthur ward, 07-14-2007 16:50:54
Arthur..... .while I've never had the occasion to weigh the frontend axle, I'm guessing at about 500#. This should be well within any motorcycle tire capacity. Remember, you ain't goin' 90mph with yer tractor. Iff'n sidewalls look low, put more airpressure in. Simple, eh?..... ..Dell
ButtonRock
07-15-2007 06:59:17
 Re: 2N/9N fronts wheels... in reply to Dell (WA), 07-14-2007 19:24:28
Does anyone know of a cheap motorcycle tire that will fit a 19 by 3 rim. Would like them to be as big and round as possible. I am lost when it comes to two wheelers. Also some sizes seem to be metric continuing the confusion. Tia
Dell (WA)
07-15-2007 09:53:25
 Re: 2N/9N fronts wheels... in reply to ButtonRock, 07-15-2007 06:59:17
Buttonrock..... ...why do we haffta do yer work for you??? Go SHOPPING yer self. Simple, eh? Dirtbikers are always trading in their knobbies. Plenty of wear left for yer tractor. You don't like that idea??? There is always "google"..... ..respectfully, Dell
2N new guy
07-14-2007 11:21:22
Dell, Thanks for the reply. I know the 3" is/was standard issue wheel. I got the tires covered. 7.00/19. Just wanted make sure it was indeed a 4" rim so I can run my tires. Now does anybody make a 4" blank? Anybody have any other info? And I have about 20 - 16" x 4" passenger car wide 5 if anyone wants to go 16" .
2N new guy
07-14-2007 10:35:13
