cam busings?
aaa
07-14-2007 10:49:49
Dose the cam shaft have replacable bushings?
Dan
07-14-2007 14:56:10
 Re: cam busings? in reply to aaa, 07-14-2007 10:49:49
third party image
I had to replace my 1948 8N block due to internal cracks. The replacement 1948 8N block had replacement cam bushings installed. It was a professional job and my machinist was impressed. I should have put a new cam shaft in though as after the full rebuild my oil pressure drops to just under 10 psi and I am pretty sure it is clearance in between these bushings and used cam shaft.
Anyway, this is an oddity and you don't see it often.
Dan
Jason SImmerman
07-14-2007 13:07:10
I've heard of our motors having Ford flathead V8 cam bearings installed in them. Never done it myself, just what I've heard.
Bob
07-14-2007 10:52:32
No, at least not unless a machinist has reworked the block, and installed them.
aaa
07-14-2007 10:57:48
 Re: cam busings? in reply to Bob, 07-14-2007 10:52:32
Then does the cam shaft have somekind of bearing or bushing on it?
TheOldHokie
07-14-2007 11:01:04
 Re: cam busings? in reply to aaa, 07-14-2007 10:57:48
The cam runs directly in the bore of the cast iron block.
TOH
aaa
07-14-2007 11:09:45
 Re: cam busings? in reply to TheOldHokie, 07-14-2007 11:01:04
Then I take it the camshaft journals are made of softer material so that they wear instead of the cast iron block, or maybe cam shaft journal wear isn't normally a issue with these engines?
Bob
07-14-2007 11:16:06
 Re: cam busings? in reply to aaa, 07-14-2007 11:09:45
The block AND the camshaft are both made of cast iron, and both do wear, USUALLY not enough to cause problems.
As I said before, I have heard of folks line-boring the block to accept inserts. I have no idea of what specific inserts they'd use, but engine bearing catalogs have a progressive size chart for inserts, and it's often possible to find one from another application that will allow something like this to be done.
aaa
07-14-2007 11:26:48
 Re: cam busings? in reply to Bob, 07-14-2007 11:16:06
Ok, Thanks for the Info..
