Order Ford 8N Parts Online
Re: More 8N throttle and rpm questions
Dell (WA)
07-15-2007 19:49:55
third party image
Chipper..... ...you may need to inspect yer throttle linkage for "slop".
But most likely, its yer "governor". Yer governor balls gitt flatt spotted and the cone race they roll on gitts grooved. Both can be repaired. To check yer governor, with engine running about 1/4th-throttle, grab yer carb to governor rod (it won't bite you) and try and "jazz" yer engine for more RPM's. Does it "fight you"??? NO? bad governor. Rebuild kit $100 (cheap) Replacement governor $250; yer call..... ....Dell
Chipper
07-15-2007 19:59:49
 Re: More 8N throttle and rpm questions in reply to Dell (WA), 07-15-2007 19:49:55
I know when giving it throttle and watching the arm on the carb where the rod comes in from the throttle does not move until you move the lever a considerable amount and then it'll jump. Also, unless the two arms where the governor are tied together, it will try to run away.
Dell (WA)
07-15-2007 20:28:26
 Re: More 8N throttle and rpm questions in reply to Chipper, 07-15-2007 19:59:49
Chipper..... ..I don't know how to make this more understandable. ITS YER GOVERNOR. rebuild it. Squander $25 for the I&T FO-4 manual. It even has pictures for the mechanically challenged..... .respectfully, Dell
Chipper
07-15-2007 21:11:03
 Re: More 8N throttle and rpm questions in reply to Dell (WA), 07-15-2007 20:28:26
Thanks for the info Dell.
