Order Ford 8N Parts Online
1948 8N Governor
Hiney
07-16-2007 04:35:13
I have a question about the governor that is on my tractor. Currently once I move the throttle a little from idle it will take off. I hear this is a sign that the governor needs repaired. I have put another governor on the tractor from another 8N and it seems to work fine so I took the old governor apart to look at it and the balls look okay, only the tinyest bit of flat spots. The housing however has wear in it. The question is will an internal rebuild fix the governor or do I need to get a whole new governor? Any help that you can give me will be appreciated.
Thanks,
Hiney
Indiana Jones
07-16-2007 18:39:41
 Re: 1948 8N Governor in reply to Hiney, 07-16-2007 04:35:13
This is posted just down the page from yours. May answer your question.
