Oil Pan
russ b
07-17-2007 10:10:08
Thanks to Dan and Henry for the heads up on the "extra" front bolts behind axle support.
To me those are dangerous. When I put it back together, I will cut the heads off two bolts and slot for screwdriver. The holes need to be pliuged with something if they go through to the oily side. I will give em a dab of epoxy to keep em in place.
Loosing some oil I can live with, it leaks anyway, busted iron would ruin the day. YMMV
souNdguy
07-17-2007 10:51:34
 Re: Oil Pan in reply to russ b, 07-17-2007 10:10:08
Screwdriver slots?
How about just studs and nuts?
Soundguy
russ b
07-17-2007 11:53:25
 Re: Oil Pan in reply to souNdguy, 07-17-2007 10:51:34
SouNdguy, I was meaning to just plug the holes and not use them for fasteners, for fear they will go unnoticed next rNr and Murphy's Law. I don't want me or the next guy to break something expensive.
While on the subject, the reason I went in, is that when I rebuilt the engine I could only get one of the gears. My OP has been sort of low. I have the 9/16 gears and don't know weather to up grade to 3/4 or just put a kit in what I've got. Engine runs strong. Any thoughts?
souNdguy
07-17-2007 12:18:47
 Re: Oil Pan in reply to russ b, 07-17-2007 11:53:25
Do you mind geting it line bored?
Soundguy
russ b
07-17-2007 12:40:00
 Re: Oil Pan in reply to souNdguy, 07-17-2007 12:18:47
Ah, line bore would be a problem, at this point.
