490 Haybine Belt dilema
PATF
07-18-2007 18:05:35
I have recently picked up a older NH 490 Haybine that needs a the rubber belt replaced. I can get one end of the belt in and around the wobble box/belt wheel but I am unsure how to get the other end of the belt in and around the top wheel that is connected to the gear box/drive shaft. A manual did not come with the machine. Thanks for you help.
Randy(PA)
07-20-2007 21:04:52
 Re: 490 Haybine Belt dilema in reply to PATF, 07-18-2007 18:05:35
Did you get an email from me? I had this site send one to you, asking you to email me so I can send you a scan from the manual.
Tom 8N396936
07-19-2007 04:03:07
If I understand you correctly you will need to pull the shafts at the top- my buddy just did it on his - not easy- get the manual- and good luck.
tom
