Order Ford 8N Parts Online
52' 8N hydraulic
Roy H
07-20-2007 04:52:55
OK men, the 3-point wont stay up if I push in the clutch.I have rebuilt the piston and re-installed. With the right side inspection cover off I can now see a steady stream of oil comming from the the pump by way of the PTO shaft.Before I call 911 what do you all think? And yes it's still rainning here in Austin Texas.
Dell (WA)
07-20-2007 05:32:09
 Re: 52' 8N hydraulic in reply to Roy H, 07-20-2007 04:52:55
third party image
Roy..... ..the "squirts" by the PTO shaft is yer sparkplug shaped "pressure relief valve" stuck open. $30 (cheap) Do a search on the archives for a "bending" treatment for 11/16 wrench handle and you can replace it without having to drop yer hydraulic pump..... ..Dell
Russ SoCal
07-20-2007 19:08:57
 Bargain bin bent wrench in reply to Dell (WA), 07-20-2007 05:32:09
third party image
russ b
07-20-2007 11:37:28
 Re: 52' 8N hydraulic in reply to Dell (WA), 07-20-2007 05:32:09
I'm guessing the nonsocket end comes forward.
Top View
                              =====O                ^     bend here?
Roy H
07-20-2007 06:17:31
Thanks Dell for the quick response I hope thats it.Roy
